I use Directory Opus 12.28 here at my office and then also at my home. Is there a way to share the settings so that they both use the same ones. If one is updated, the other is as well. Possibly via Dropbox?
I'm also looking for a solution so that when I create a script or shortcut on one computer, it will work on the other as well. The problem is that the path to folders/file are different on each machine. Ex. my work is C:\Users\AaronSko..... and my home is C:\Users\Aaron...
I've thought about using Relative Path's to solve this. Before I go changing all of my shortcuts and scripts, would this work and/or does anyone else have a solution ?
Using aliases and/or env-vars instead of direct paths solves that. The built-in /profile alias covers that case, but you can also add your own aliases if there isn't a suitable built-in one.
With custom aliases, you'd want to avoid synching the config file that contains the aliases between machines, of course.
