SHIFT key does not work on Send To menu
Hi,
Just started using DO, In Windows Explorer I used to press SHIFT while
clicking a Send To menu item to move that file, Unfortunately that
doesn't work with DO v9.0.0.9, It just copies the file.
Any ideas?
The other notice is, unlike Windows Explorer, I can't make menu selection
with right mouse button, I have to release the right mouse button then press the left mouse button, While in Explorer i just keep the right mouse
button pressed until i select the menu item which i want to execute, then
i just release the right mouse button and the command is executed.
This is faster and much more convenient to use than having to use/switch
between the two buttons.
Is there an option/workaround to enable this in DO?
Thank you for taking the time for reading this.
[quote]Just started using DO, In Windows Explorer I used to press SHIFT while clicking a Send To menu item to move that file, Unfortunately that
doesn't work with DO v9.0.0.9, It just copies the file.[/quote]
I just tried in Windows Explorer and it doesn't seem to work that way for me, at least in the situation I tested it in.
I'm using XP SP2 at the moment and had a text file on my Desktop. In Explorer I right-clicked the text file, hovered over Send To->My Documents, then held Shift and left-clicked. The file was copied (not moved), the same as happens when Shift isn't held down.
Are you using a different version of Windows? Or does it depend on where you are copying from and to?
Are you talking about file context menus or something else? As in the above case, Explorer behaves the same as Opus for me. In both programs the right-click context menu does not even appear until the right mouse button is released.
