Hi there.. o)
I noticed for several weeks now, that my "drop everything in here"/"what a mess"-folder took
up to 10 seconds to get displayed in a dopus lister. I have just about 500 files in there right
now, so that cannot be the problem. I tracked that delay down to a shortcut-file, these files
which end with *.lnk.
The file which is linked to by this *.lnk-file is on a remote pc, specified by an UNC path.
The computer where that files resides is down, so the file is not available. Whenever DOpus
comes across this link-file, it takes very long to complete the directory listing. Even if I
isolate that file and put it in its own directory.
MS-Explorer does not delay while listing this file and accessing the directory from another
system over LAN with MS-Explorer does neither. But it does always "hang" when listing with
DO (if that file is local or on a LAN/UNC-path). So it seems Dopus is the "problem" here.
I had a look into the settings, but could not find anything regarding accessing or "touching"
these kind of shortcut-files.
I attach that *.lnk-file in a zip, perhaps you might want to try for yourself ?!.. This even
occured with DO-v9. Don't be scared by the filename, that shortcut was created unintentionally
and contains this path: "\192.168.2.1\d$\bin\s\RunBatchInvisible.bat D:\bin\s\startup-sequence.bat".
Again: This is a simple shortcut, there is no batch or script in there!
And yes, I have a "startup-sequence" on my windows machines.. o))
Thank you!.. o)
Rob.
Shortcut to RunBatchInvisible.zip (839 Bytes)
