Shortcut to navigate to next folder in sequence
Very simple problem, but I have a main folder containing numerous subfolders where I organize images. Is there a way to quickly open the next folder in sequence using a keyboard shortcut? For example, if I’m currently inside folder DV79, I’d like to jump directly to DV80 by pressing something like Ctrl + Alt + Down, without needing to click the folder with the mouse if that makes sense.
Thank you :slight_smile:
Here's a way to do that:
If you use the example buttons, you can add a hotkey to them, or copy their commands into a standalone hotkey (if you don't want the buttons taking up space in toolbars/menus).
Thank you, it worked perfectly.
