Showing infotip when CTRL pressed
infotip appears when CTRL is pressed, when the mouse is not hovering over them.
How do I turn this feature off, please?
This setting is turned off.
The infotip of the last selected item are still showing when Ctrl is pressed.
Preferences/File Displays/Options/Info Tips/Only with key held down
Unchecking and re-checking the option can solve the problem, so I didn't report it.
Does not fix issue here :frowning:
Try changing 'Keyboard delay' to 0 milliseconds.
Thanks. that seems to work :slight_smile:
