Hi sometimes i do big copy operations.
it will be good there can be option to sleep or shutdown pc after copy operation.
and if error occurs , skip option can also be good.
Make a button or hotkey which runs Close SYSTEM=shutdown WHENFINISHED and use it after the operation is started.
More detail in the Close command documentation.
For skipping errors, click the Unattended mode option in the progress dialog.
Note that if you combine both things, the system will shut down and you will have no record of whether or not there were any errors, since the window with a list of skipped files will not be there after a reboot.
Is there a way to get the system to sleep or hibernate rather than shut down? There does not seem to be such option for "Close SYSTEM".
Not currently, sorry. Maybe we can add it.
