I need a toolbar button which duplicates the selected files.
The "Copy Duplicate" function pops up a dialog requiring a rename pattern.
I would like the button to include the rename pattern.
I need a pattern which suffixes a number to the existing filename: "Filename.xyz" to "Filename 1.xyz"
If "Filename 1.xyz" is already existing, it should be renamed to "Filename 2.xyz"
Also, I need a button which copies selected files to a different location and automatically renames in the above manner, if similar filenames already exist.
Can someone help me out with such buttons. Thanks!
