Dear Support,
following your rules for silent installation of Directory opus I installed this software (via SCCM) since version 9 without problems. Starting with version 11.13 it fails.
For updating from version 11.10 to 11.13 I create a setup.iss file with "setup.exe -r" moved this to my install package and and deploy it whit "setup.exe -s" to my users. Launching it in the SCCM "Software Center" a error window come up (see attachment): "Critical Directory Opus components do not match", Program version 11.13.0, Library 11.10.0. and Directory Opus is only partial installed and unusable on this PC. Can you help me with this?
To solve this problem by myself I tried the uninstall scripts from InstallShield ("C:\Program Files (x86)\InstallShield Installation Information{5D4F167D-CCC8-413E-A6EE-F2FABBBBF50D}\setup.exe" -runfromtemp -l0x0409 -DentalFloss -removeonly ), but there are also not "silent" and need user intervention.
I hope you find a solution for this. ![]()
Thanks in advance
Alfred
