Hi!
Simple for anybody that has at least a basic technical expertise, which I don't.
I am trying to configure another app (specifically, Listary) to use DOpus istead of WinExplorer.
The image shows DOpus' path, but I don't know what parameters are needed to have it open in the path I select. The way it is now it opens DOpus, but doesn't go to the folder I selected, it simply opens it wherever it was open previously.
I need to know what parameter(s) to enter in the line below (or modify in the upper line)
I appreciate your help and thank you in advance.
spj
This is what you need, in Listary General options.
Regards, AB
