Small mistake(?) in color picker dialog
Hi,
are the predefined colors in Color Picker Dialog coming from Dopus or Windows?
If from Dopus then there is a small mistake in the top row, second from right color.
It is set to 92,92,92 should be 96,96,96 :slight_smile: if we take into account what is in front and what follows.
Thanks.
They are just some preset colors. There isn't meant to be a rigid pattern to them.
