Is it possible to have an even (real !) simpler Find box ? It takes up too much space for quick simple daily use (find all *.png files).
It is sized for advanced use, especially the "Find in" folder list section (never used it)
99% of the time I need a one-liner: Find: w*.txt, case insensitive, include subfolders !
As you can see, I'm not a fan of busy toolbars, but this could be better than the current situation. How do I get that search field back ? Right click doesn't list a "Search/find" item in the available toolbars.
Edit : found it (Search command, not Find)
Edit: this is perfect (wildcard, case insensitive, subfolders) ! Thank you.
