The suggestion is
Add a setting for the number of lines to be displayed for Command Completion
At present, the command completion can display up to 10 lines, and then you need to scroll down with the scroll bar, wasting the display space of the list
add evaluator in Command Editor - Function Definition - Type
I hope to support Lbutton, Rbutton and Mbutton parameters for keyargs, such as
keyargs Rbutton:newRight-click to open in a new window
keyargs Mbutton:newtabMiddle-click to open in a new tab
The little Bug found is
@hideblcokCommands don't work with dynamically generated menus (like 'go DRIVEBUTTONS'), hope to fix that- After updating dopus13.3.1 Chinese version, the new option entries are still in English, hope to fix the translation
- Enter Chinese in the dopus option search box, only accept the first Chinese character, hope to fix it
For example, when I search for "标签," only one Chinese character "标" appears in the search box
