"Lister" is just another name for a normal Opus window with a file list in it.
You need to create a Folder Format for the path in question if you want it to display in a particular mode. The FAQ on Folder Formats should explain all you need to know.[/quote]
[quote="CWBillow"]That seemed to fix it. What was it and why?
Also, is it a lister I need to set up now to have this folder show up in single-pane icon form?
[quote="jon"]You wouldn't have a file called "target.lnk" in that RegIDs folder would you?
If so, try deleting it and see if it fixes it.[/quote][/quote]
Found it! They are junction points, or folder redirects. So perhaps something you installed on your PC (other than DOpus) must have created a juntion point between the folder you were trying to get to and the one you ended up at.
I'm sorry, I'm a bit slow... how can that fix my issue if at all?
Chuck
First off, this is all new to me, but I tend to learn quick
I hadn't realized that I had ever used junction points directly, until just now.
To see how they work, try this:
[ol][li] Create a folder named "Test" directly on your Desktop.[/li]
[li] Open the folder (doesn't matter DOpus or Windows Explorer)[/li]
[li] Create some shortcuts to real files inside of the Desktop\Test folder.[/li]
[li] Close the Desktop\Test folder[/li]
[li] Click on the Desktop\Test folder and drag it to your Start Menu (just on the main Start Menu, not in Programs). This creates a program group on the Start Menu.
You just created a junction point.
[/li]
[li] Hover your mouse over Start Menu\Test, it should show all the shortcuts that Desktop\Test had. (But these are not copies!)[/li]
[li] In Directory Opus Find, search for target.lnk. (It must be Directory Opus, Windows Explorer won't show them.)
My system-wide search shows a target.lnk for each of my network locations that show up in My Network Places. The properties of each can be viewed and each displays the \computername\sharename of its network place. I also have a target.lnk listed for the Start Menu\Test group folder that I just created above.
According to the article I linked, this is what a target.lnk file is for—redirecting a local file or folder to somewhere else. The Start Menu\Test group you just created is an excellent example of this. You dragged a folder full of shortcuts to the Start Menu and Windows copied them there, creating a group with shortcuts in it, right? Wrong!
What really happened is that, behind the scenes, Windows created the folder %SystemDrive%\Documents and Settings\User Name\Start Menu\Test, inside of which Windows also created a target.lnk file that contains a junction point to the Desktop\Test folder. We will now prove this.
[/li]
[li] Try to list the folder %SystemDrive%\Documents and Settings\User Name\Start Menu\Test each of the ways below (in Windows Explorer or DOpus, it does not matter):[ul][li] Right-Click on Start Menu\Test and click Explore[/li]
[li] Open a lister to %SystemDrive% and drill down a folder at a time.[/li]
[li] actually type the explicit path in the Path bar and press the Go button[/li][/ul]
What happened? In all cases, you will end up at this folder:
%SystemDrive%\Documents and Settings\User Name\Desktop\Test
not at
[/li]
[li] Now open the Command Prompt, and CD into %SystemDrive%\Documents and Settings\User Name\Start Menu\Test[/li]
[li] Type Dir and press .
You will see one file...target.lnk
[/li]
[li] Type del target.lnk and press — Windows puts up no fuss at all, the file is deleted and you just broke the junction point.[/li]
[li] Close Command Prompt[/li]
[li] Goto your Start Menu\Test Group and take a look at it, its there, but its empty and its dead.[/li]
[li] Open your Desktop\Test folder, everything is still there.[/li][/ol] Target.lnk files are obscure little buggers. And you won't see them when browsing in Windows Explorer. I believe they are an "alternate stream" file, similar to the Zone Identifier files that Windows creates when you download executables from the Internet. (DOpus only shows me those when I download to my Iomega Rev Drive, which uses the UDF file system).
My best guess is that maybe you drug a system folder to another location once (which can re-route system folders like My Documents or My Pictures), or somehow re-routed one of your folders once, and that created a junction point.
There is next to no documentation on these either Googling for target.lnk Site:microsft.com only get four hits.
