Split 4k 55" monitor into Multiple monitors
Just bought a 55" inch monitor that I am using with Virtual Window Manager.
Directory Opus does not enter a tile layout. It behaves as if there was no desktop divider and tiles.
It does, however, show Virtual Window Manager's buttons in the titles of it´s page.
Is there something I can do to continue using Directory Opus?
Thanks.
I don't know how that tool works, but Opus uses the standard Windows APIs to fine out where screens are and so on. That tool must be modifying them in some way which doesn't affect what Opus does.
Opus has built-in support for loading and saving window layouts, and also positioning windows into specific coordinates and sizes, if that's what you need.
