Good sirs.
What do I need to reset/throw away to make DOpus the default standalone viewer?
Even though I have it set under Preferences/Double click On Files, Windows Photo Viewer has suddenly hijacked all my jpg viewing.
Thx
Good sirs.
Thx
Another location is -> settings -> file types -> system file types -> search for the "JPG" entry. It should
be set to open with Opus viewer.
back in business - thanks
