Hello,
I use Opus on multiple PCs with fine-tuned controls/custom buttons set in the configuration on one PCs.
Obviously I would like to have the same configuration on the second PC and the best way to do is to export the configuration from the source and import it in the target, which I have done numerous times.
However recently I have seen the backup configuration option giving the strange error of access denied error code (5) on any drive where I want to create the backup file. (I have all the NTFS permissions for all drives).
Screenshot:
Has anybody got a clue for the same. I did configure upload to my Flickr and ImageShack account from Directory Opus, however these settings have no effect on this problem.
Thanks.
