Strange behavior when used with PeaZip
I am satisfied with using DO (Directory Opus), but one thing that is disappointing is that it does not support zst.
Therefore, I installed PeaZip, which supports zst, but I am having problems using it with DO.
When I clicked "PeaZip > Add to Zstd" on the selected folder, it worked correctly in Windows Explorer, but when I used it in DO, it behaved strangely.
Please refer to the attached screenshot.
Can I get some help solving this problem?
Thanks for the report. A fix for this has been made and will be in 13.3.2.
I didn't want to install the beta version, so I was patient and waited for the stable version.
Today I checked v13.4 and it works exactly as I expected.
Thank you for your help!
