A strange situation occurs in the viewer pane in Opus 9 with some PDF documents. It does not occur with PDF documents that I personally create of various items on my screen, using the free software "PDFill PDF Writer". But apparently only on PDF documents that I have brought up on a web site, and then saved to my computer.
When I browse a folder on my computer, and put the focus on one of these documents, an error message comes up on my monitor display.
The error message is
Your current security settings do not allow this file to be downloaded
Then the viewer pane displays
Navigation to web page was cancelled
What you can try
Retype the address
There is no problem opening any PDF documents (just by double clicking on them) in Adobe Reader 9.0.0. But I cannot understand why the Opus viewer generates this error message. Somehow it appears to be linking that filename to a web site, which of course is not proper. The original web site from which the PDF file was saved was not a restricted site.
What is happening here?
Ron Hirsch
