I use Pro-Version 13.10 on Win 11 Pro x64.
When I rename a file and press the STRG-key with down arrow, a popup appears with the last file names. Can I switch this off or move it to another key?
Uncheck Rename - Inline in Preferences / Miscellaneous / Privacy.
Thank you very much, that's what I wanted ![]()
