Issue:
Added a bunch of nested folders to a collection ("add as sub collections"). Can't find a way to get rid of them short of going into each subdirectory, selecting each file, and doing a 'remove from collection.'
Isn't there a way to do "remove from collection" on a group of nested sub collections? If so, I'm not finding it. If not, I'm really going to regret doing a bulk addition!
Thank you,
Rob
P.S. I wish the collections would allow treating them even more like regular file lists. Especially allowing the exteneded listing methods.
Thanks for the info - I was worried about using delete because there's always the caution of "delete here and you'll delete the actual file" with collections.
And yes, flat view - specifically flat view with all the nested directories and files. This way you could add a bunch of "buried" directory structures to work on at the same time.
