[Suggestion] Allow using system context menu
Hi, can an option be added for Dopus to use the system context menu so that it can work with e.g. GitHub - moudey/Shell: Powerful context menu manager for Windows File Explorer?
Then it wouldn't work with all the internal Opus commands, script add-ins, and so on.
You can do a lot of what that tool does in Opus already, too.
understood! i do need to further maximize Dopus by utilizing the features you mention above
as far as the tool goes, what i like most about it is the visual consistency it brings for the rest of the system. if Dopus 13 enables users to somehow recreate the same theme/style then I'm happy
I'm not sure visual consistency is a thing in Windows anymore, thanks to Microsoft's string of half-finished UI style changes and ever-changing whims. :slight_smile:
yes, haha.. i try as much as possible but 3rd party tools can only go so far, like putting bandaid on a gunshot wound
