Suggestion: thumbnails view & mouse cursor position
When using thumbnails mode, this always annoyed me a bit, although it´s the logical behavior: whenever the cursor is accidentally over a file, that file will be selected. After reading the current fixed list for vrs. 9.1.1.7
"Drop-down menus opened via the keyboard now ignore the position of the mouse cursor; previously if the mouse happened to be where the menu opened, the item under the mouse would be selected."
i think, this likewise would be a beneficial option for the thumbnails mode, if possible. The "mouse over" behavior could be altered in the preferences, selecting a file would explicitly require a mouse click then.
I don't think I understand what you're saying.
Files are only selected if you click them (or use the Select command), unless you've turned on Preferences - Listers - Options: Single click to open an item (point to select - does not apply to Power mode) in Opus, in which case you presumably want that to happen.
Files are only selected if you click them (or use the Select command), unless you've turned on Preferences - Listers - Options: Single click to open an item (point to select - does not apply to Power mode) in Opus, in which case you presumably want that to happen.[/quote]
Hmm, that´s true, i do have single click mode activated, to be more precise. Anyway, it would be nice if it would be possible to have the single click behaviour turned off while in thumbs/tiles modes. It´s no big deal, but sometimes a bit irritating.
