My excellent DO shows my SVN column 'SVN revision'.
The only thing that could be better is the sort that now isn't numeric yet.
Will this change in the future?
It might change if you send a feature request.
If anyone has Tortosie SVN on Windows XP or below, can you check if Explorer sorts the column numerically? The column won't appear at all in Explorer from Vista onwards so I can't easily compare what Opus does with the column to what Explorer does.
Works fine on W7 now.
Just for your administration.
