(If it's a folder, that will open the folder itself. If you need it to open the folder's parent and select the folder, that's possible but slightly more complex.)
Note that if you're doing this from code, you can use the Windows API for showing the parent folder and selecting something. If Explorer Replacement is enabled in Opus, the API will be redirected to Opus, and your code does not have to worry about whether the user has Opus or File Explorer or what the default file manager is, as it's taken care of automatically.
