I had reason to change the tagging on all MP3 files from 2.4 to 2.3 recently.
I then tried using D.O. 9.5.5.0 3889 to synchronize the files to an existing folder that serves as backup for audio files.
None were selected for syncing.
I then ran a profile from Super Flexible File Synchronizer and the files were copied to the backup.
No filters were used in the sync panel. Sync subfolders and ignore seconds were selected.
I tried again with some files that I changed the case on a few tags. None were selected in D.O, all were copied with SFFS.
