Sync, multiple searches and slower
a distinction must be made between the following:
local drive to local drive
multi read in = comes from non-functioning bracketing out.
forget to close firefox first.
crash = at least 3 or more consecutive read operations
firefox cannot be closed due to usage.
no automatic *.dmp is created.
a manual dmp creation does not work because the task manager cannot decide
what to display from dopus.
switches between apps and background process with different listers (is the same)
and executions. (multiple display although only 1x open)
it does not update the opus entries!
the lister entry for the crash is therefore not available to click on!
local drive (complete) to nas (in directory)
no crash, firefox directory does not exist there, but long waiting time.
start before comparison
during the calculation, therefore shutdown needed, the value doubles!
looks like the existing directory (already calculated)
and the currently checked directory (runs through subdirectories) are added again!
before open saved layout
before start sync comparison (calculation available)
during sync (calculation with subdirectory)
Use the Details tab in Task Manager.
in the release description for 13.3.1 it says
Improved Synchronize exclusion list logic.
unfortunately the exclusion still does not work properly!
the message with "content changed" when the browser firefox is open
still appears.
the same happens when the microsoft edge browser is open.
this has also been added to the list.
cache data is also in the same subfolder as firefox.
the automatic setting of \ * on selection is still missing.
however, subsequent editing now works.
Zwischenablagebild (2)
makes no difference in use
the biggest annoyance with this version.
does the sync action now take even longer?
Is the issue still under review?
It remains cumbersome to close all programs so that the sync works.
It now also affects other directories that are not in the mentioned D:\PSpeicher.
It does not matter whether these directories were used as fixed or temporary file storage.
The exclusion of these directories is still ignored.
Content changed" is repeatedly displayed when data is accessed in the background
Also the slow and strange behavior when comparing (calculation cannot be switched off)
and after ending the action (file changes visible in the lister for up to 1 minute) still occurs.
Looks like you are right. With or without the asterisk, the folder is included:
Using just the folder name works:
So does prefixing the path with an asterisk:
Odd or cool? You decide :wink:
In 13.5.3 we'll make it ignore file changes. While it can mean the comparison results are no longer valid I can see how it can make sync very difficult to use in some situations. We may bring this back in the future if we can work out a simple way to ignore changes in folders you've marked for exclusion.
newly added when excluding does not work in 13.5.5!
you have to manually put the * behind it again so that this is excluded.
J:\Desktop -> J:\Desktop* (the \ befor * not show after send, in edit see it?)
or edit
J:\Desktop -> Desktop (note from lxp)
