This is my first time using Opus (I'm evaluating 8.2.2), and I find that synchronize filters appear to not work properly. In this example I want to filter out hidden files/folders, but as you can see from the attached screenshot hidden folders are included in the result.
I've even tried excluding the specific hidden folder names in the filter, and it still doesn't work. But the same filter works when doing a find operation.
thanks...tai
[/img]
