Synchronize not working with DOpus 13 and SFTP. Pressing compare switches to Find Panel
How to reproduce on Directory Opus 13.3 Build 8823 x64
Open two folders, side by side.
Left side is SFTP source (other types work as expected)
Right side is any other destination
Open Synchronize panel
I've tried virtually any combination of settings. Always same result.
Click Compare.
No comparison starts. Directory Opus simply switches the pane to the Find Panel with the destination selected.
Don't think I am doing anything wrong (worked on DOpus 12, first time I am trying this on DOpus 13). Hope you can replicate and debug this.
Thanks
Do you still see this in 13.4.3 beta or later?
I can't reproduce it, but that may be due to some recent fixes for Sync with (S)FTP.
Hi, can someone tell me how to get the display to show the which files will sync? in the helpfiles, they are shown as checkboxes with arrows showing which way the file will transfer. I cant see any settings in v13
i want to see similar to this display
That happens automatically after you push Compare in the Sync panel.
Please start a new thread if you need further help with this, unless it's related to Sync + SFTP specifically, which is what this thread was about.
