Hello,
I found a bug in shutdown options. When using countdown in xx seconds, a value of max. 59 is accepted. A higher value doesn't work. You can reproduce it disabling QUIET option.
Hello,
From the manual: The time is specified in HH:MM:SS format (or MM:SS or just SS).
Ah, thanks Leo, I thought DO counts down in seconds only, so I set higher values than 59!
