Hi guys,
I want to create a system-wide hotkey to enter a text string, for example my email address which I get fed up of typing into certain form fields on the web.
It's just the syntax I need, I can handle the rest.
Regards
Roly
Hi guys,
Regards
Roly
Opus can't type things for you but it could put the text into the clipboard (Clipboard SET ).
If you want auto-typing there are several clipboard history tools which also do that. The Keepass password manager can also do it.
Thanks Leo, the Clipboard method will do fine
Can this be done using an external application instead...? I've heard people talk about AutoHotKey but from what I've read I can't see any mention of text string input. Any suggestions...?
Yes. Many of the clipboard history programs can do it, as can the password-storage programs such as Keepass.
AutoHotkey / AutoIT can send keypresses as well.
[quote="leo"]Yes. Many of the clipboard history programs can do it, as can the password-storage programs such as Keepass.
AutoHotkey / AutoIT can send keypresses as well.[/quote]
Ah, didn't realise Keypass could do that as well, I'll take a look at it. Cheers Leo.
More info on Texter here (since I looked it up anyway I figured I'd paste the URL).
Also has links to the compiled & uncompiled code, in case you come to this thread at a later date. (The code attached above is version 0.6 which is the latest now, but might not be forever.)
[quote="blueroly"]Hi guys,
Regards
Roly[/quote]
PhraseExpress is highly recommended.
