Tabmove always moves to dest, need option to keep
Hi folks,
can we have a tabmove option so that we can move the current tab within the same pane (source or dest)
so that is operates like tabselect
e.g.
I use key to execute with result
control-PageUp go tabselect +1 select next tab in source
control-shift-PageUp go tabselect +1 openindual select next tab in dest
I'd like to use a similar set of keys to move the selected tab or tabs later in the list
... for mutiple tabs, so that non-contiguous to be put adjacent, and moved, in one operation
for both the source and destination panes
How possible would this be ?
... perhaps a new TABSHIFT argument for the GO command ?
it also seems that the newly-available object model does not provide a tab.index query / settable property , idea ? ....
or an .invalidate method, to indicate refresh-required, idea ? ...
Many thx,
Brian
The next beta update will include a new Go TABPOS command to do this.
Thx Leo, do we have an ETA for that ?
August 1st, 2014.
