This script adds a TabDedupe
command to close duplicate tabs, but with a default option to protect (not close) the current tab so you could just add it to your open new tab/close current tab shortcuts/buttons and not have to manually invoke any dedupe commands, but also not worry that the newly opened tab will be deduplicatedly closed¹
It can also operate on both lister panes
Supported arguments:
right
close dupes from right to left (default)left
close dupes from left to rightnoprotect
close current tab if it's a dupedual
close dupes in left/up and right/down panes
¹ you could also add a dedupe command before opening a new tab, but this had strange side effect of opening a tab at the end of the tabbar instead of near the active tab when you tried to open a 3rd dupe tab
Cmd.TabDedupe.opusscriptinstall (4.6 KB)
