AI Mode fail no matter which model selected. I have setup Open AI key in environment but still same issue. Do I need to install Ollma locally?
Alongside the AI content feature, could you also make an auto rules feature plz.
You would set up automatic rules for adding tags. "If file is added to x parent path, then add these tags." If my path is c:\good\blue, then something added to the good folder would get the "good" tag. If added to the blue folder it would get both the "good" and the "blue" tag. If any tag already exists then ignore it.
Or rules for "if x happens then add y tag". If a file is in my projects folder and is copied, then the original gets a "VER1" tag (version 1). The copy gets a "VER2" (version 2) tag. Or SOURCE and COPY tags, etc. If VER2 is already on the copied file it would increment to VER3, removing the VER2 (up to VER5. If "VER5 then VER5.").
And a find and replace tags feature. If I add STG3 tag then check if any STG# tags exist and remove them first, then add the tag. (The same thing already happens with ratings and dates. If I change the star rating of a file it doesn't now have two ratings. No, it removed the old rating and added the new one).
What would be cool is if we could have tag groups. For any group I would have to choose only one tag out of the group. Each group has its own proprietary choices. A drop down menu for each group, to choose the tag, one for each, no more no less.
I've wanted dopus to do these things for a while now.
