Recently, with updates from ms and Dopus, I've noticed my statically positioned Dopus toolbar (docked at bottom of screen) turns blueish-white when I close a different desktop java application. Then, the taskbar icons do not refresh until after the mouse cursor is moved across each icon.
Any suggestions for how to prevent this behavior?
Here is what I am seeing after I moved the cursor over the 4 visible icons.
In this case, ThinkorSwim is the Java application. The behavior seems random and not easily duplicated. No other windows are affected.
Since posting my question, I have added dopus.exe and dopusrt.exe to the windows 11 "high performance" graphics setting (forces use of AMD graphics card). Perhaps this will make a difference.
What is the Toolbar's Appearance option set to currently? Taskbar, or something else?
Does the problem only happen with Taskbar/Glass/Transparent, or does it also happen with Frame/No-Frame?
Does it happen if the toolbar is at the top of the screen instead of the bottom?
It looks a bit like something placed edit controls on top of the Opus toolbar, but I don't know why that would happen or how you would stop whatever it is from doing that.
Appearance is set to Frame
I did try to "inspect" the bar for a handle value (in case there were edit controls), but hovering the mouse over the blue bar caused the bar vanish.
I will have to experiment before answering the other questions.
If it's on Frame, Taskbar may work better with the other program.
If the other program is drawing on top of the toolbar for some reason, Taskbar mode may stop it as it uses a layered window which I think is harder for other things to draw on top of.
But it's also possible the other program is creating controls that vanish when the mouse goes over them, or maybe even sending messages to the wrong window which happens to be the toolbar, and which might have quite random results.
Are there any path fields, spacers, sliders, etc. on the toolbar, or is it all simple buttons?
