Hi guys,
Attached there is a TGA file with 1x1 pixel. We're using files like this very often as dummy frames and placeholders. It's a valid file, Photo-Shop, Irfan-View and XN-View can read it without problems, but Dopus cannot.
TGA format is quite simple, so I checked the header and everything is valid.
I agree that the thumbnail is not very meaningful for a 1x1 pixel bitmap, but not be capable to obtain the valid bit depth and other information is a big disadvantage when searching for files with a specific bit depth, type and so on.
A fix would be much apreciated.
Thanks,
Kind regards,
Skeeve
Dummy.zip (167 Bytes)
