Thanks for v9 - and sync prb using FTP
Hi Greg, hi developpers, hi all,
First, thank you for v9: from what i see, it is even faster than v8! And stable. It appears you made many improvements.
A particular issue: When I try to 'synchronize' between an FTP-SSH-port-22 folder and a local folder (a shared drive's folder), Dopus opens a sync lister, but sometimes it cannot access the remote ftp folder in the sync window. Checking site properties, the port is on 21, instead of 22, thus no chance to connect.
Best regards
Freddy
Could you click on Tools -> Output Window in the menus, then switch to the FTP #1 tab, clear it (to avoid confusion), and then attempt a sync and see what the output says?
