i didn't want to make new thread for these small questions; i hope this is ok~
1.) if i have opus in a mode where a file display is smaller in length than the filename (eg. filmstrip mode in details mode) and the turn on checkbox mode, if i then try to inline rename a file, opus automatically jumps all the checks out of focus. this is to show as much of the name as possible in the short window to facilitate renaming, no? is there any way to turn this behavior off?
2.) since i started using checkbox mode a few days ago, i've loved it! is there anway, though, to tell opus to line highlight all checked boxes or to check boxes for all line highlighted files?
3.) is there a way to make it so that if one double-clicks unused space in a lister, opus will go up one directory?
Correct, and there's no way to turn this off unfortunately. Maybe it should auto-scroll back to the original position once inline renaming is finished?
Pressing space will check the boxes for any selected (highlighted) files.
(Actually, it toggles the check state)
Not currently but we do have this on the list for possible inclusion in a future version.
[quote]Correct, and there's no way to turn this off unfortunately. Maybe it should auto-scroll back to the original position once inline renaming is finished?
[/quote] as an option, that would be nice!
[quote]Pressing space will check the boxes for any selected (highlighted) files.
(Actually, it toggles the check state) [/quote] i see~ is there any way to highlight select all the files that have been checked?
[quote]Not currently but we do have this on the list for possible inclusion in a future version.[/quote] i'll look forward to it!
Not currently. Is there a need for this? In check-box mode the highlight status of files doesn't really matter (since all actions are performed on the checked files.)
[quote]Not currently. Is there a need for this? In check-box mode the highlight status of files doesn't really matter (since all actions are performed on the checked files.)[/quote] if going from checks to highlight were built in, that would be nice, that it's not is ok, too~ the use to me would be in a case where i have lots of item checked, i could push the button and those files would be highlighted for programs that don't natively recognize opus' checkboxes (eg. winrar from windows context menu). i think i could just make a custom button to send the checked files into winrar or other program...
