Hey all,
What would be the best solution to have Opus show thumbnails from software like Illustrator, Cinema 4D, HDR/EXR files and so on?
I tried one before but I felt it slowed down my machine by a lot
thanks in advance
Elad
Hey all,
thanks in advance
Elad
Just to follow-up on this, Opus will use whichever thumbnailers are installed on the system. If they work with File Explorer, they should also work with Opus.
As to which thumbnailers are best for those products / formats, we don't know. It's a question better asked on the forums for those products, where you'll find more people who use them and are expert in them. The question doesn't really involve Opus at all, unless you find a thumbnailer which works in Explorer but not in Opus for some reason (in which case we can investigate that), so it's outside of our areas of expertise.
Hey Leo,
Thank you for your reply!
I am trying now to work with - https://www.fastpictureviewer.com/codecs/
Still finding out if it's the best solution RAM-wise and so on..but so far it looks like it works great with OPUS.
It's not free but it's worth it
same as Opus !
thanks
Elad.
