Hey folks, have had a good look for help on this but I think I need specialist advice.
I use Autodesk Inventor extensively for my engineering work, love using Dopus but would like to customise a little more to suit my work-flow.
I would like to be able to display the properties associated with all the Inventor files in tiles mode.
Currently the infotip displays the required properties correctly but I would like to customise and am unsure which codes will work for tiles mode.
I have attached a sample Inventor file if this helps.
File meta-data is called iproperties.
Many thanks from a programming illiterate grease monkey.
AI part.txt (186 KB)
