Tiles info question
It seems, that there is some redundant information inside the »mp3artist« tag, so that the songtitle is repeated.
Is there a way to change this? Also, i saw an example of the tiles view, where the name in the tiles info was in
bold typeface, how can i set this?
I'm not sure the left and right things match up at all so you might be editing the wrong thing (maybe the wrong filetype or filetype group). For example, the song length isn't reported at all on the left but is specified on the right.
That aside, the repetition you are seeing is because the filename includes information that is in the music tags. If you only want to see the filename or only want to see the tag then just delete one of them from the filetype or filetype group. (Making sure it's the right one.)
Ok, it was some (default? Must have been long ago, when i set this, maybe from the presets) »file type« settings, & i had it set in
»all files & folders«. I removed now the name item & now it is like i wanted it, thanks. By the way, the previous settings actually showed
the time, mostly. Perhaps some settings collided in that example. Now after having cleaned up the settings from »all files & folders«
all is ok. The only problem in this solution is, that some files might have no ID3Tag information at all. But in that case i can switch to normal
details view.
Somehow i messed up that function. Info shows only the first three items, no file or dirs count whatsoever. I´ve looked in the file
types, Zip, all folders & files, folders, nothing. Interesting thing is, when i remove the info tip code from the file groups "archives",
the only info tip showing a file count, & an always empty directories count (even if there are subdirs), so it has to come from somewhere.
