And something is wrong with it, or how it is configured.
It's not an Opus issue, since the same is happening in Explorer. Whatever is wrong is more general than just one program.
It's more likely to be related to whatever other software you have installed, rather than the quality of the hardware. Either way, it's nothing to do with Opus.
He's got to be using an emulator right? DOPUS doesn't have a MAC version AFAIK.
You can run Windows on Mac hardware these days.
Probably it's a faulty Logitech keyboard driver.
Or more probably, it is a bug in Parallels: The overriding feature with SHIFT/CTRL obviously does not work with Windows 10 installed on a Parallels VM because Parallels obviously does not translate the keypress of a single modifier key without pressing a character key at the same time to the VM. So this probably seems to be a BUG in Parallels.
Eureka, now it works!!!
This is how to set it in the German interface:
And this setting has been changed while the VM is running!
I've updated the thread subject to include OS X / Parallels to help anyone else with the same issue find it.
If you run into any other strange issues, please mention the fact you're running inside a VM / emulator as it's quite important, on top of checking if the problem only affects Opus or is system-wide.
