Hello,
I just upgraded to Directory Opus 11.5 x64 and I am running into a problem when I use the lister drop down menu to switch between lister modes (e.g., switching from a single to duel vertical lister).
Specifically, my customized toolbar configuration switches back to what appears to be the default toolbar configuration whenever I switch modes. Please see the attached video capture.
Am assuming that this is a configuration problem or bug as the problem did not occur in previous versions.
A fix would be appreciated.
Thank you…
2014-07-08_19-36-29.zip (1.24 MB)
