Hello,
I joined DOpus from the total commander world. So typically I use DOpus 10.2 in the dual lister view with 2 side by side listers without treeview. To change drives either in either the left or the right lister, I created 2 drive button bars with have either set OPENINRIGHT or OPENINLEFT to open in the according lister.
Unfortunately unlike Total Commander, the focus is not automatically set to the according lister in which the drive was opened. I'm aware that you can use [ALT]-Tab in a second step to focus but I'm looking for a one click solution.
To accomplish this I tried to extend the command behind the "Go DRIVEBUTTONS=fixed OPENINRIGHT" with a second command "Set FOCUS=Right".
I tried various combinations (First setting focus, then use the Go DRIVEBUTTONS) or each alone.
The commands do both work if used in a standalone button. If I use both together, only the first one will work.
Any ideas if and how this is solvable?
Best regards
Sascha
