Hello. i found only a topic with dynamic renamer that was 9 years ago. may be there is a new and simple method to transliterate names like in totalcommander(sorry, never use it, but found this possibility in it via search) Dopus's find&replace doesn't accept () | or *
Using a rename script would be best for that, if you mean mapping one character set to another. It's not something you can do with a single regex, wildcard, or search & replace operation, but it'd be easy to do with a little script that loops through each character and replaces it according to whichever rules you want.
i just found
function translit_file($filename)
$converter = array(
'а' => 'a', 'б' => 'b', 'в' => 'v', 'г' => 'g', 'д' => 'd',
'е' => 'e', 'ё' => 'e', 'ж' => 'zh', 'з' => 'z', 'и' => 'i',
'й' => 'y', 'к' => 'k', 'л' => 'l', 'м' => 'm', 'н' => 'n',
'о' => 'o', 'п' => 'p', 'р' => 'r', 'с' => 's', 'т' => 't',
'у' => 'u', 'ф' => 'f', 'х' => 'h', 'ц' => 'c', 'ч' => 'ch',
'ш' => 'sh', 'щ' => 'sch', 'ь' => '', 'ы' => 'y', 'ъ' => '',
'э' => 'e', 'ю' => 'yu', 'я' => 'ya',
'А' => 'A', 'Б' => 'B', 'В' => 'V', 'Г' => 'G', 'Д' => 'D',
'Е' => 'E', 'Ё' => 'E', 'Ж' => 'Zh', 'З' => 'Z', 'И' => 'I',
'Й' => 'Y', 'К' => 'K', 'Л' => 'L', 'М' => 'M', 'Н' => 'N',
'О' => 'O', 'П' => 'P', 'Р' => 'R', 'С' => 'S', 'Т' => 'T',
'У' => 'U', 'Ф' => 'F', 'Х' => 'H', 'Ц' => 'C', 'Ч' => 'Ch',
'Ш' => 'Sh', 'Щ' => 'Sch', 'Ь' => '', 'Ы' => 'Y', 'Ъ' => '',
'Э' => 'E', 'Ю' => 'Yu', 'Я' => 'Ya',
$new = '';
$file = pathinfo(trim($filename));
if (!empty($file['dirname']) && @$file['dirname'] != '.') {
$new .= rtrim($file['dirname'], '/') . '/';
if (!empty($file['filename'])) {
$file['filename'] = str_replace(array(' ', ','), '-', $file['filename']);
$file['filename'] = strtr($file['filename'], $converter);
$file['filename'] = mb_ereg_replace('[-]+', '-', $file['filename']);
$file['filename'] = trim($file['filename'], '-');
$new .= $file['filename'];
if (!empty($file['extension'])) {
$new .= '.' . $file['extension'];
return $new;
echo translit_file('/upload/Пример файла.jpg');
or this
function translit(word){
var answer = '';
var converter = {
'а': 'a', 'б': 'b', 'в': 'v', 'г': 'g', 'д': 'd',
'е': 'e', 'ё': 'e', 'ж': 'zh', 'з': 'z', 'и': 'i',
'й': 'y', 'к': 'k', 'л': 'l', 'м': 'm', 'н': 'n',
'о': 'o', 'п': 'p', 'р': 'r', 'с': 's', 'т': 't',
'у': 'u', 'ф': 'f', 'х': 'h', 'ц': 'c', 'ч': 'ch',
'ш': 'sh', 'щ': 'sch', 'ь': '', 'ы': 'y', 'ъ': '',
'э': 'e', 'ю': 'yu', 'я': 'ya',
'А': 'A', 'Б': 'B', 'В': 'V', 'Г': 'G', 'Д': 'D',
'Е': 'E', 'Ё': 'E', 'Ж': 'Zh', 'З': 'Z', 'И': 'I',
'Й': 'Y', 'К': 'K', 'Л': 'L', 'М': 'M', 'Н': 'N',
'О': 'O', 'П': 'P', 'Р': 'R', 'С': 'S', 'Т': 'T',
'У': 'U', 'Ф': 'F', 'Х': 'H', 'Ц': 'C', 'Ч': 'Ch',
'Ш': 'Sh', 'Щ': 'Sch', 'Ь': '', 'Ы': 'Y', 'Ъ': '',
'Э': 'E', 'Ю': 'Yu', 'Я': 'Ya'
for (var i = 0; i < word.length; ++i ) {
if (converter[word[i]] == undefined){
answer += word[i];
} else {
answer += converter[word[i]];
return answer;
but it doesn't work with rename script and i'm not familiar to edit it properly. is anybody can?
