I reinstalled Opus and no change.
Opus will not open TXT files with a double click. It will open a JPG file with a double click. Windows File Explorer does open a TXT files with a double click.
Many thanks.
Many thanks.
Most double-click issues can be fixed by right-clicking one of the files and using Open With > Choose Default Program.
But, for text file specifically, check under Preferences / File Operations / Double-click on Files to make sure you don't have Opus configured to open them in a text viewer/editor which no longer exists.
If you still have issues, go to Settings > File Types, then File > Diagnostic, create a diagnostic for the .txt type, and attach it here or in a private message.
Thank you. Nothing worked.
Under Preferences / File Operations / Double-click on Files - Text viewer (blank for default) I added:
C:\Program Files\WindowsApps\Microsoft.WindowsNotepad_11.2205.11.0_x64__8wekyb3d8bbwe\Notepad\Notepad.exe
I changed the Open With selection to WordPad. Double click works.
Thank you,
M. Cook
