Hi,
In File Explorer (don't hate me), if you type 'cmd' into the path/location text box it will open a Command Prompt in the current folder.
I notice that Opus does not have this feature. It's not a problem as the right click context menu gives us this functionality already (just like FE did until they removed it by default and you had to turn it on via some power user util or something).
I was wondering whether there was a good reason why Opus has not included this feature, or if it is in the pipeline.
Many thanks.
You can press > and type an arbitrary command in Opus. The path field is for paths
Brilliant, thanks Jon.
I just knew there would be another (better) way to do it.
Opus rules!
