UI issue when setting a Filter
If I have a filter long enough to require a horizontal scrollbar and Edit as text is enabled, sometimes I end up in a state where the controls are visible and interactable, while the textual filter is also present.
Thanks! Fixed in the next update.
Confirmed. Thanks for the fix.
