Hi Leo, I switched to the previous Lister window and checked what differences there might be in Display options. I shrinked the first column in it and tried to use Ctrl+Num+ shortcult and it worked. All columns were properly resized.
The only difference with the last used Lister window is that columns were not set to autosize in the last used window.
So it seems that the issue is worked out.
The only problem is that when file names are long, I hate to display them at their full length. So I disabled Autosize option.But then the keyboard shortcut is not any longer working.
Thanks anyway for your help and patience.
