Unattended copy minor UI issue
In Opus 12.20, when copying the files, if you check the "Unattended operation" checkbox and uncheck it (the window auto closes), then minimize the progress window to a Jobs bar, when you restore it, the Error list window will also pop open.
Thanks! Fixed in the next update.
