jimerb
1
I'm wondering why "Unattended Operation" is missing for deleting files?
Sometimes I have to delete 20,000-50,000 files and if just one of them is in use, the whole operation stops. The deletion can take 20-30 minutes.
Seems like a gap.
Any plans to add this?
Leo
2
Maybe in the future. It's a good idea, just one we haven't got to yet.
Leo
4
Oh, I was thinking of copy queues rather than unattended mode. My mistake.
Note that if you delete via the Recycle Bin then Windows handles that. The unattended option will only be there when deleting files directly.
jimerb
5
So it's there? I'm not on the latest version but I will upgrade if it is.
Leo
6
There has been for a long time. You're probably deleting to the recycle bin if you don't see it.
jimerb
7
Great! Thanks for the info. I'll check it out.
